R Reg Ford Fiesta Radio Help
Andy
Hi guys,
I'm after a bit of assistance if possible, I had to have some work done on my car earlier this week and as they had to do some welding they disconnected my battery and now I can't listen to my radio.
Could someone tell me where I find the serial number so I can give ford a call to try and get the code for this ? My radio is a 4000rds IIRC.
I've looked through all of the documents I have and it's not written anywhere, unfortunatley the guy that this was purchased from has no idea what it is either :( :facepalm:
DELUCAS
serial no should be on the side of unit or on top of casing !
you may need to remove unit to see !
quoting the car reg plate to fords may be of help but you need the original no plate where the stereo come from ! to save you removing unit.
obtaining the code number is availabe from the internet but at a charge !
and fords will charge you as well normally :(
Andy
Just tried that code, first attempt putting it in and it's displaying the message "WAIT 30:00" and has begun a countdown, have turned it off so it'll have to continue the countdown on my lunch break but I assume that means it's incorrect.
If only I had the radio manual :facepalm:
DELUCAS
yes incorrect code !
The more incorrect codes you put in the more waiting times you will have to wait .
I think it may lock you out as well if my memory serves me correct ?!!
if you have many attempts etc .
DELUCAS
Darn :facepalm:
I've rung the local ford dealer and you were correct, they want to charge me £15 in order to retrieve it for me..
try googleing car codes on net there are some companys that will do it cheaper :smashin:
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
