+R playback question
Discussion in 'Blu-ray & DVD Players & Recorders' started by lochindaal, Dec 21, 2004.
  1. lochindaal
    lochindaal
    Nov 21, 2003
    138
    Do any HDD DVD recorders play back +R discs apart from Phillips.
    Doesn't have to record to +R.
  2. RonBos
    RonBos
    Nov 21, 2004
    35
    11
    The Netherlands
    +5
    My Pioneer 720 does.
    Ron
  3. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    Most DVD players/recorders will playback a properly authored DVD+R. That said use DVD-R if you can as more machines will be able to read that format.
  4. cj28
    cj28
    Panasonic DVD recorders won't play DVD+R unless the booktype of the disc has been set to DVD-ROM rather than DVD+R when finalising. This is a bit of a pain if you use DVD+R discs recorded on a PC drive without the ability to write using the DVD-ROM booktype. I eventually returned my Philips DVDR890 after repeated faults and got a Panny HS2 and also now a E55. Unfortunately I was left with a reasonable number of blank DVD+Rs and DVD+RWs which are now useless...
    CJ
