Qwners of Pioneer series 6. Help please.
Discussion in 'Plasma TVs Forum' started by alwyn, Oct 23, 2005.
  1. alwyn
    alwyn
    Dec 10, 2002
    570
    west country
    +13
    Can you please tell me if you are able to use the optical digital audio output on your 506 or 436 media box,I ask because my unit will not.
    Many thanks
  2. Chris Blackwell
    Chris Blackwell
    Not tried that as I have the opticals from the Sky+ box and DVD player going directly into my Lexicon DC-2 SSP and by-passing the Pioneer Media Box altogether. I think I saw a menu item somewhere though, isn't it under 'Sound'?
  3. kmitty
    kmitty
    Apr 1, 2005
    29
    3
    I have mine connected to a YSP-1 - works fine
  4. alwyn
    alwyn
    Dec 10, 2002
    570
    west country
    +13
    Yes with Sky I do exactley the same,but I was refering to using the built in freeveiw tuner and connecting up to my mc12 with digital.
  5. alwyn
    alwyn
    Dec 10, 2002
    570
    west country
    +13
    Did you have to activate the digital connection?
