Quite Disappointed with the AE700... (and its not just VB!)
Discussion in 'Projectors, Screens & Video Processors' started by robyoung, Nov 22, 2004.
  1. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Right guys,
    I delved in to the PJ market a few weeks back and with all the raving about the AE700 i went for it with out a viewing (i know silly me!) and to be honest i'm not that impressed, :mad: ok the colours and brightness are fantastic but i have one particular problem which is hard to explain (its a sort of shadow effect), when something dark and 'prominent' comes on screen, it will leave a green shadow to the left of it, i've tried some tweaks in the options but with no luck. has anybody had something similiar, i have a picture of the effect which i'll try and post up. :confused:
    Also the VB to my eyes is unacceptable!! Ok the flicker tweak minimizes it, but it never really goes away. Plus you have to do this flicker tweak about once ever half hour while the PJ warms up, which is no good when you're watching a tension building film! Whilst watching Trainspotting (class! :thumbsup: ) last night i found it very distracting! (it seems to appear worst on shades of Red/orange)
    Have anyone else had the same problems with a similiar set up? I am considering returning it and swapping for a different PJ. So what are my alternatives. I need a short throw lense, lense shift and a good zoom, preferably an RGB Scart socket but not essential)
    My current set up is running through an RGB Scart, approx 12-13ft away from a 8ft (106") screen. it is zoomed 100% and lens shift is slightly down (as its celing mounted). Will any of these increase the problems i'm having?
    Thanks for any ideas/advice!
    Rob
  2. Darwock
    Darwock
    Green shadow to the left of prominent things on screen? Ehhh... what? Sounds like a duff unit. There's nothing like that with mine.
    I'm also zoomed all the way with lens shift almost all the way down.
  3. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
    Sounds like a dodgey unit,contact the retailer and see what thet say.The only VB i have is on sky sports and its not that bad.
    Can you post a picture of your problem?
  4. stuthemong
    stuthemong
    Dec 31, 2002
    432
    +6
    soulds to me like a panel alignment problem - do you get a red haze the other side of the dark objects?
  5. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Here's a pic of the problem. (hope it works) this is when it shows up the worst, but also happens on films etc. (when i was watching Red Dragon, there was a shelf top the left of Ed Norton and he ended up with green line on his face)
    [​IMG]
    Excuse the poor quality, it was taken with my phone. I cant really get a pic if the VB but i tend to notice it constantly.
    Rob
  6. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    No, it seems to be clear the other side. Very strange, i'm glad it's not a common problem will contact the retailer and see what they say. (it was discount electrical) so hopefully the will be fully sympathetic! :)
    rob
  7. stuthemong
    stuthemong
    Dec 31, 2002
    432
    +6
    whoa. that isnt right!!!!!!!!!!!!!!!
    either your source is doing something very strange - can you test on a different DVD player or something? or the projector is faulty.
    Dont fret mate, it isnt meant to look like that!!!!
    stu
  8. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    Dodgy unit by the look of things. If possible connect to a component lead or vga lead(through PC) when watching DVDs. I changed my X-box/Playstation to a component connection and the difference is amazing!
  9. jamesgrahamuk
    jamesgrahamuk
    Definitely a faulty unit.
  10. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Thanks for the advice. I'm pretty sure its not the source, as the picture I posted was from Sky+, it does it on DVD playback and on my PS2 as well.
    So the vote is Faulty unit, I'm going on holiday on Wednesday so will have to sort out a replacement when I'm back next week. Will it be a problem there now being 30 hours on the clock?? (also not sure if I've still got the box!) oops!
    Being hopeful, maybe this problem has increased my VB, I havent heard of too many others having such VB, most say it is negligible. In fact I thought mine was negligble until I decided to be clever and do the flicker tweak for the first time, I'm probably just imagining things but I swear it got worse after that!
    I forgot to mention, the PJ is connected through a Quintro+ scart box so I can switch between that and the Plasma, I'm sure this isnt effecting things, as my Plasma picture seems to be fine!
    Cheers again!
    Rob
  11. Aquila
    Aquila
    Oct 14, 2004
    69
    9
    Bruges - Belgium
    If I were you I'd first try connecting the DVD-player directly to the PJ instead of through the scart box before taking it back. I've had a bad experience in the past with a scart switch with similar strange colour effects. The problem was bad contacts.
  12. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    Faulty unit is my guess too. Get a good 'un and you'll soon have a smile on your face.
  13. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Just called Discount Electrical, and they are collecting it tomorrow! Excellent service! :thumbsup:
    Hopefully I should get it back when I'm back off holiday. :)
    I'd be interested to hear from anyone who has a similar viewing distance to Screen Size ratio on their experience with VB, and whether it's as noticeable. I'm thinking about getting a smaller screen, although really don’t want to, I've got used to the screen size and its perfect for that 'cinema like' feel.
    Also does the connection (RGB, Component, HDMI) make any difference to VB?
    Rob
  14. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
    Im using a 7ft screen from 10ft away,only noticed a little bit of VB on skysports channels.Have my sky+ connected by scart.DVD player connected by component is an excellent picture,can't fault it at all.
    Looking at your picture i would say your unit is faulty,hopefully when you get it back the VB issue will also be sorted.
  15. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    That looks awful mate - im sure youll love the projector when you get a new one.
    Mine seems to be from a newer batch, has no problems, completely unnoticable VB and picture is just astounding. It gets better the more I watch it!
    Good luck with the new one :)
  16. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
    Even on sky sports?Must admit now i have 60 hours on mine the picture does seem to be getting better and better. :D
  17. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    Have you thought that it could be a bad RGB cable? If the shielding isn't right, you might get such interference. Anyway, if you get it back and it still does it, try changing the cable or try a different input ( S video or component)
    Good luck!
  18. Aquila
    Aquila
    Oct 14, 2004
    69
    9
    Bruges - Belgium
    hi explicitlyrics,
    could you read the production date of your pj on the sticker on the bottom of it and post it here?
    Thnx :)
  19. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Thanks for the help again!
    I tried it this morning direct to Sky/DVD etc (instead of through the Quintro) and it was still the same, unfortunately i couldnt try a different cable instead of the RGB Scart as it's a 10m one and i have no others lying about.
    Anyway, its been collected from Discount Electrical today so we'll see hwat happens.
    Rob
  20. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    My AE700 was produced in October 2004. So it is possible that there are slight differences but I really have no idea.
    What are other peoples manufacturing dates?
  21. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    650
    +7
    Definately a faulty unit Rob as I've got an AE700 & a 105" DRH Screen @ about your viewing distance. No VB at all on any type of connection (HDMI-Component-Scart-S-Video-VGA), used em all. Hope that helps.
  22. joffonon
    joffonon
    Dec 4, 2002
    105
    Westcliff-on-Sea, Great Britain
    Agreed. I'm getting a perfect picture with a 10m SCART lead from my Sky+ box.
