quintro help
Discussion in 'Plasma TVs Forum' started by JIMMY, Mar 4, 2005.
  1. JIMMY
    JIMMY
    hi lads can you help
    got a quintro today
    looking 2 connect to my js rgb 2 vga con
    its a bit hard as the scarts keep falling out of the quintro
    when im puting them in and they feel loose even the power hole for the lead is a bit lose feels cheap are these usualy well made
    any way quintro does work but unsure how all the leads go
    i put rgb scart from sky in 2 tv 1 on quintro
    then put a scart cable from quintro used number 3
    and put in to rs rgb 2 vga converter
    audio still in to the js rgb 2 vga
    should audio go in 2 quintro then from quintro to the js box
    sorry to go on please help
    i have got a good pic but want 2 make sure its done right
    jim :confused: :confused:
  2. w3dal
    w3dal
    Aug 4, 2002
    5,063
    Chelmsford, Essex
    +593
    Jimmy,
    You finding the output much much better the when you had the mediabox connected??
    Dal
  3. JIMMY
    JIMMY
    hi well not sure if sll conected right
    dvd is going through coponent
    its much better than on media box
    im sure skys better but cost for all cables
    2x scart =
    1 composie cable+ board
    js vga box quintro box
    1 vga 2 vga cable
    it is better but at a cost if youve got the cash great
    if a bit short id hang on with the media box
  4. w3dal
    w3dal
    Aug 4, 2002
    5,063
    Chelmsford, Essex
    +593
    Im happy with the output from the mediabox and i seem to get a good picture from Sky so at the moment everything is cool.
    I will at some point upgrade, but i think next on the list is a DVD recorder!
    Dal
