QuietPC Power Supply
Discussion in 'Desktop & Laptop Computers Forum' started by simonp, May 20, 2003.
  1. simonp
    simonp
    Not surprisingly they are quiet power supplies that are meant to make your pc perform a lot queiter than regular pc's.
    Has anybody got one of these and if so what is your opinion?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I had a 300W model for a bit. It was very quiet. I swapped it for an enermax in an attempt to solve a video noise problem I was getting with Dscaler. Didn't improve things over the quietPC PSU and it was/is louder.
    However I couldn't be bothered swapping them round again and sold on the quietPC PSU...probably not a smart move but I'd had enough of tweaking that week.
  3. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
  4. jitter
    jitter
    I just bought one of these....
    Levicom 350W ATX PSU Blue Fan LED
    from here> http://www.aria.co.uk/DisplayProducts.asp?Submit=Search&Category=96
    Its so quiet you wouldn't know its on except for the lights. Really pleased with it. Think it's 19db at low loading, which is very quiet. I run mine externally (offboard psu) connected by 25way d connector and I'm using stainless steel overbraid (car kit) to cover the cables & for screening so 1, you lower the pc heat and 2, psu EMF & RFI are removed and it runs so cool it stays at 19db!
    www.levicom.de
    specs on there..
    neil
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    I have an ordinary 300w PSU, and all I did was replace the standard 80mm fan that was inside, with a 19db Papst fan fro www.quietpc.com.
    It's a standard case fan, and easily replaced. Been running it like that for over a year now, with no ill effects.
    HTH
    Gary.
  6. Loafer316
    Loafer316
    Apr 8, 2003
    330
    I've heard good things about the thermaltake psu's (420watts) anyone have one?
    @gary :zonked: :suicide:
  7. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,314
    Berks, England
    +140
    I recently replaced an Enermax whisper 365W with a Zalman 300W and yes, its quieter.
    No increase of video noise seen on TheaterTek DVD playback running off the Zalman, which is good, although I've yet to try it with the pb tv-100 capture card and Dscaler.
    regards,
    Rob.
