Quiet proctor
Discussion in 'Projectors, Screens & Video Processors' started by mcmental, Jun 28, 2015.
  1. mcmental
    mcmental
    May 20, 2010
    39
    Hi there I'm in the market for a Mid range projector around £5-600 I need it to be as quiet as possible though due to it being located overhead above the sofa :-( at minute I've got a cheap Chinese HQD model(bought to see how I liked having no TV)
    What can you all recommend please.
    Used for TV and films,no gaming.
    Needs to have hdmi input though.
  2. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
  3. boots10
    boots10
    May 17, 2015
    3
    4
    York
    Just read the review of that Epson and it says it is quite noisy.
    I am after exactly the same thing mcmental .... The Panasonic AE6000 is really quiet ( 22db) and the Sony VPL HW40 is 21db. Both well over budget though .
    I'm still looking .... Must be long throw for me too !
  4. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    Yes it is noisier than the larger chassis models but other than that in his price range you are looking at DLP models which are usually even a bit louder.
    A second hand Epson TW3200 or Panny LCD at under £400 would be around 22db in eco mode so would be a better option as far as audible noise is concerned.
  5. mcmental
    mcmental
    May 20, 2010
    39
    I need to find a place I can go listen and look. Was on a course at work other day and he had an aptoma and it was about a 10th of the noise of mine.
  6. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    Well if you can live with an Optoma DLP regards noise and rainbows (not that they are bad for either) go for one of those.
    I have an older optoma HD20 1080p model and sit 3ft from it and don't find it too noisy.They do 2-3 models in the £500-600 range that offer great images and generally reliable.
    HD141x/151x/HD26
    Optoma HD141X Full HD 3D 1080p Projector: Amazon.co.uk: Electronics
    Optoma HD26 White | 3D DLP Projector 1080p HD Ready | Richer Sounds
    Optoma HD151X Black | 3D DLP Projector 1080p HD Ready | Richer Sounds
  7. mcmental
    mcmental
    May 20, 2010
    39
    Other than my own that is the only other projector I've ever heard running, I will find a shop I can go and see some working before I take the plunge.
