Quiet PC?
Discussion in 'Desktop & Laptop Computers Forum' started by petrolhead, Jan 9, 2005.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    I am wanting to make my PC quieter.
    I am told the best CPU Cooler is the Zalman CNPS7700
    But what about the power supply and Graphics card
    I currently have an Antec case with what is supposed to be a quiet fan but thats not the case.
    Can't afford and Fanless power suppky but would like a suggestion as to the quietest
  2. imh
    imh
    Hi, I've recently bought a few components from quietpc; a case fan and a Zalman CPU cooler; both made a huge difference so I trust their judgement...
    Here is their PSU page Quietpc PSUs
    Hope that helps
  3. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    yup, i found quietpc great. Two comments, the hard drive enclosure made my hard drives get extremely hot (70degrees) so beware of those if they still sell them. Also I found the case fan I bought the noisiest component in my PC, I have since added a noisier one to cool the hard drives so its not that big a deal. The decibel ratings are accurate :)
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    The problem with a fanless psu is that you then have to have an exhaust fan to remove the air from around the psu, if you choose a psu with a 120mm fan such as a seisonic or nexus, around £50, they will both help pull the air away (albeit throught he psu but that doesn't seem to matter too much). The less total fans the lower the noise floor.
    The Zalman cooler is good but the thermalright xp120 is better, see http://www.silentpcreview.com/article209-page1.html for a detailed comparison.
    What processor and graphics card are you trying to cool?
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Hi John
    Thought you would slope along at some point :)
    Good question
    I am running at 3.4 P4 775 and the Nvidia 6500gt
    The PC is not overstretched ie I don't play games, just office work, surfin and from time to time video editing
    Thanks IMH but you don't state wich one you got
  6. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I've got a 350w nexus in my htpc but also have a seisonic 300w in one of my desks (the quiet pc thing is spreading through the house, once you get used to the quiet you need it :) ).
    My htpc is a 2.6 p4 northwood running at 3.13 with a thermalright sp94 (the xp120 predecessor) and runs very cool, no case fans at all. Used to have a 9600 fanless but have just swopped to a 6600gt and added the new zalman cooler to restore peace.
    For you intel 775, I dont think the xp120 fits yet so you'll have to use the Zalman.
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Have read the article and yes I would agree John you are correct.
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    I was going to say that but then checked on the Thermalright web site and followed a link to http://www.overclock.co.uk/customer/product.php?productid=17955 Only £3
    Now its just a case of finding a good 120mm fan. They used the Globe fan but the only place I can find one is in france
    Just a thought but instead of replacing the PSU could I not replace the fan with a quiester one? Which one tho as this justs exhausts at the back or am I trying to be chbeap and shoould just replace the PSU?
  9. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    The benefit of changing the psu is that a 120mm fan exhausts air from the cpu area better, it mans the cpu fan wont have to work quite so hard, if you have a fan on the back it will only be an 80mm so will be noisier for the same airflow.
    What psu is it, the standard Antec?
  10. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    PS Which Zalman Graphics cooler
  11. Fe+
    Fe+
    Apr 29, 2003
    281
    Cheshire
    +5
    is this the antec sonata you have ?
    I am looking at one for my next upgrade and after something quiet and cool
  12. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Yes the 'true 350'
  13. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Fe+ Yes, its the sonata
  14. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    The Antec PSU is one of the better 80mm variants, I'd be inclined to change the cpu and vga fan first and see where your at, I've got a 2.8 prescott in another machine and the stock fan was very loud compared to the 2.6 Northwood running at 2.87. The Prescott line definitly need servere cooling.
    The vga cooler I have is http://www.kustompcs.co.uk/acatalog/info_2844.html
    I have swapped fans in a psu before, it was a shallow desktop case that used a non-atx psu so we didn'y have much choice, it worked ok but its not upto the improvement you get from a 120mm based variant.
    My desktop machine is housed in a Nexus Breeze which uses a 120mm intake fan at the bottom of the case and a Nexus 120 psu at the top with insulated sides etc, similar to your antec.
  15. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    One thought
    If I go the Thermalright route how will i control the fan speed, thro the mobo or the PSU. The Zalman for instance has a rehostate (spelling)
  17. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Yes, the psu is not the very quietest but is "up there", its one I have two of and represents decent value/noise performance.
    The vga I have and the XP120 is the one I would buy today if I was in the market.
  18. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    My existing Thermalright with an sp94 and 92mm papst runs off of a mothorboard header, through a Zalman fanmate on the slowest setting. You coiuld just run the fan at 5v but the fanmate gives you a chance to vary the speed according to your requirements.
    Just as an aside some mobo manufacturers dont recommend running 120mm fans from the mobo header, I think its something to do with the amps required to get the fan spinning although I have some in my server with no problems.
  19. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
  20. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
  21. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    My Seisonic is the 300w model, not the 400w one that you linked, in the real world I think there is little to choose between them. I bought the Nexus for my HTPC because I had convinced myself (un-necessarily) that the 300w wasn't coping.
    My setup is currently quieter than the Sony HS10 in the same room and that is rated at 23db.
    I understand your concern, I put the 2.8 prescott in my desktop breifly but it was much much louder than the overclocked 2.6 northwood so I relegated it to a machine in the garage now running xlobby/multiroom-music, so the noise is unimportant, both used the retail hsf but the prescott needed a much higher fanspeed to keep it cool (the mobo controls the fans in my dektop).
  22. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Didn't see the other post....
    The 80mm might be quieter at 12v but if you slow them both to the same noise the 120mm will move more air, moving the same amount of air a 120mmm is normally quietest.
  23. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Yes, been reading some more and the consencious is either Nexis or Seasonic getting slighter better marks
    Also seems that Nexis fans get top marks
    Off to play with my new All in one Jamo system
    As always been great chatting to u=you John, you have been most helpfull
    Peter
  24. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Let me know how you get on with whatever you pick.
  25. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Will do
  26. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
