Quiet graphics cards
Discussion in 'Desktop & Laptop Computers Forum' started by sted, Apr 11, 2005.
  1. sted
    sted
    Jan 20, 2004
    79
    Bit confused about graphics cards. Can you tell whether it's fanless or not by the chipset or the manufacturer? For example, can i assume that every ATI Radeon X300 will be fanless? Or is it only one's made by Sapphire etc?
  2. lisag
    lisag
    Jul 14, 2004
    5,681
    Essex
    +333
    No you can't assume that - you need to check on the manufacturers website what the specs of the card are.
  3. sted
    sted
    Jan 20, 2004
    79
    Just to confirm - by the manufacturer you mean the likes of sapphire/gigabyte etc? On that note, does anyone know which makes of the Radeon X300 are fanless?
  4. lisag
    lisag
    Jul 14, 2004
    5,681
    Essex
    +333
    Yes, that's what I meant, or you could check with the retailer who you are proposing to purchase it from, easier if they have pictures on their website, but not always to be trusted - I don't know the answer to your other question though, sorry - I expect someone else will be along soon he does.
    lisa
  5. sted
    sted
    Jan 20, 2004
    79
    ok, thanks. i guess the problem is lack of documentation - not many of the descriptions mention noise levels etc.
  6. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    We only stock fanless graphics cards and the Sapphire are amongst the best. Have used their X300 in a number of systems to good effect. Tried a few others and even some that showed graphics of the card as fanless yet had a fan when it arrived. Also be careful as Sapphire have two versions one with and one without DVI.
