Quiet Fan for 19" rack
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by u07jrb, Nov 23, 2017.
Tags:
  1. u07jrb
    u07jrb
    Aug 17, 2016
    108
    aberdeen
    +13
    Hi I recently bought a 1U fan set online was that was supposed to be 45dB but was 60dB. I have found one online at 25dB but is only half length . I would prefer one that goes all the way into the cabinet.
    Can anyone recommend a full sized 1U fan for a 19" rack that is quiet
  2. nrees87
    nrees87
    Nov 26, 2017
    201
    46
    GB
    +153
    If you're not put off by a bit of diy - you can buy an empty 1U chassis case from Penn Elcom and cut out some holes for a series of USB poweres 80/120mm fans. Finish it off by mounting a pc fan controller in the front.
    Total cost would be about £80 and you could have it any depth you require to match your rack :)
    Nate
