Quiet DVDRW drive ?
Discussion in 'Microsoft Windows' started by evolution400, Sep 8, 2005.
  1. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Anyone know of a quiet DVDRW drive ?
    I used to have a DVDROM in my MCE which was very quiet now I have a NEC 3540a DVDRW it is great fro watching original DVD9's but when I watch any DIVX on DVDR or DVDRW etc it is now the loudest part of my system because I have got it running so quiet.
  2. HSC
    HSC
    Nov 23, 2004
    1,979
    63
    Coventry
    +172
    Pioneer 109 is well rated for noise levels
    I have one myself which I use for movies - there is also a software ultiity you can get for it that sets it in quiet mode. I never got it working but the noise was non-exisitant so turns out I did not need it....
  3. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Thanks, I have a 108 so I would assume that would be similar. only its beige and I have silver case anyone know where I can buy a silver bezel that fits ?
  4. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    The Pioneer 109XL, has a Honeycomb chasis and is set as default to spin of the discs slowly so it's quiet when playing dvd's/cd's but it gets louder when copying data from cd's...
  5. OneEleven
    OneEleven
    I can recommend the HP640i
    Even at fully chat you can't hear it unless ear pressed up against it.
  6. monopole
    monopole
    Sounds like you need a piece of software to slow down the read speed of your drive - the slower the speed, the less noise it makes.
    If you have nero installed you will most likely have nero drivespeed installed too. Set the read speed for the DVD drive to something like 2x and when you watch a movie, it will barely be audible.
    Some links:
    http://www.google.co.uk/search?q=ne...ient=firefox&rls=org.mozilla:en-US:unofficial
  7. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    I was just about to post that I have done this and it works perfectly it now is not audible at all and I have set the drive to 1x and DVD playback is fine :)
