Quiet DVD Playback from HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by Gillykid, Jul 16, 2005.
  1. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Hi All
    For some reason my HTPC always plays DVDs a good 30db less than anything else on the system.
    For example, if I am watching Sky, or playing a game then the volume is fine, but should I put a DVD in I have to increase the volume an insane amount to hear it.
    Any thoughts?
    G :thumbsup:
  2. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    I assume music plays at a normal level. You have got the audio in your player (e.g. zoom or powerdvd) at 100%. Try windows media player or another player. Are you running to PC speakers or to an amp via an SPDIF lead?
  3. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Yeah, music is fine. I use Meedio, which in turn is using PowerDVDs codec i think. I have pumped the volume up in that and it doesn't seem to make a difference.
    The PC is connected to an amp via phonos.
    Anyone?
    G
  4. ukaudiophile
    ukaudiophile
    Oct 31, 2001
    452
    Lancashire
    +62
    HI,
    Does the Panasonic you use have an S/PDIF digital input? You ideally want to be using the digital output from your PC to your surround sound system. I've found that if I used the stereo analogue outputs on my last HTPC with either Power DVD or Win DVD I would find DVD soundtracks needed a higher volume setting than music played back on the same system through WMP8 or WinAmp.
    If at all possible try a full digital connection (which will also give you Dolby Digital instead of analogue surround sound from a mixdown) and that should fix your problem.
    Best wishes,
    Dave
  5. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Hi, thanks for the reply.
    Sadly the amp doesn't have a digital input - an upgrade is on the cards in a few months time, but for now I have to stick with the analogue.
    Sounds like this may be unfixable!
    G
  6. roninsrv
    roninsrv
    Have you tried updating to the latest drivers on your sound card? Could be your DVD playback s/w is having a problem with these?
  7. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    You are using 'line out' from the sound card to an input on the amp? Power DVD volume is on 100%. Have you tried using windows media player (so not through Meedio) to make sure that works fine? Have you gone to configuration in Power DVD to make sure its set to stereo output?
  8. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Yup, settings in PowerDVD are the same, and i have checked both playback in that and in Windows Media Player - but its all the same :(
    Messed around with audio settings and its now marginally better - but still no major improvements.
    I will check it is line out (and not headphones) and get the latest drivers, though they are pretty up to date.
    One thing I have noticed is that playback on titles / trailers / etc seems reasonable, but goes quiet once in a film. Anyone know the reason for this?
  9. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    Most films are dolby digital/DTS, are you sure you have got the speaker setup in configurations right. Try downloading AC3 Filter if its still not working.
  10. nikolajhendel
    nikolajhendel
    Gillykid
    I'm pretty sure Deano-b is on the right track. I had problems with sound on my (crappy) TV. The problem was that sound was AC3 - and I had ffdshow do the sound mixing for AC3. I hadn't set the output, so it tried to output the AC3 stream to a stereo set. This gave me very bad - AND very low sound.
    I would recommend you to get the latest ffdshow, let it do the sound deconding (for AC3) and set the output for "stereo". That should do the trick
  11. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Ok - thanks for the help - I will try it out and report back.
    G
  12. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Sorry to resurrect this thread - but I tried the filters and no joy - though it was probably my complete mis understanding of how they work!
    Guess I will have to wait for an amp upgrade..... :thumbsdow
    How do you set FFDShow to do sound decoding? I work with computers / programming day in day out but dont really do much with codecs / sounds!
