Quiet 60mm fans?
Discussion in 'Desktop & Laptop Computers Forum' started by ian_guinan, Jul 27, 2003.
  1. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,163
    38
    Australia
    +18
    I'm looking for a quiet 60x60x25mm fan to replace the Papst 612NGL that has just gone on the blink from my Sky+ box. I'm hoping to have the fan run 24/7 but slowed down by a Fanmate and so a 3pin fan connector would be ideal.
    Does anyone know where I can source one, or have any suggestions for other alernatives. I've seen that www.kustompcs.co.uk have them but with 4 pin power type connectors so no good for the Fanmate.
    Thanks for the help.
    Regards,
    Ian Guinan
  2. Kramer
    Kramer
    Probably not possible to mod the fan to 5/7v in a digibox - pity that :( Hence you're using a fanmate.
    Try the usual places - ocuk, tekheads, theoverclockingstore - heaps more TBH.
    Will keep an eye out while browsing - let you know if I come accross one....
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,079
    UK.
    +2,571
    RS do quite a selection of fans too. Not sure on their prices or delivery costs though.
    Gary.
  4. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,163
    38
    Australia
    +18
    Thanks Guys. Will try some of the overclocking stores. The Papst fan originally fitted is 12V and only 16db so is a good choice..problem is I can't seem to find one with the right connector..can you get the little 3 pin sockets that go onto the Fanmate/motherboard pins and fit them yourself?
    Otherwise I'm open to suggestions for other quiet 60mm fans.
    Thanks,
    Ian Guinan
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Theoverclockingstore has ceased trading, something along the lines of losing some key staff and not being able to cope.
