Quickie...
Discussion in 'Cables & Switches' started by Jazz Monkey Jr, Apr 20, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I am after recommendations for a SCART and component cables, approx. 3m long, it is for my Viera when I get one....
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    How much do you want to spend?
    The component cables in the power buy section by Mark Grant are excellent value, and I think 3m will cost around £70.
    Scart cables are readilly available in a range of quality and also with different pins connected. Do you want fully wired or just RGB? Have a look at the forum sponsor www.tvcables.co.uk for a fair range.
    Mark.
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I don't want to spend a fortune - a decent set for a good price.
    I will need audio throught the SCART aswell.
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
  5. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Thanks for that, looks just like the one I am using at the mo. but it is too short.
