Quickie re sub
Discussion in 'Subwoofers' started by petrolhead, May 5, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,788
    87
    Newcastle
    +116
    When setting up using the test tones (AV32R) should the sub be at the same level, 75db, as the rest of the speakers or higher. I seem to remember +6db but not sure. Currently all the same but just want clarification.
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Got mine set at the same (85db using AVIA).
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Got mine set to -5 - just sounds right to me. I think that's what is important
  4. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    Pete.
    You may as well set it to 75db in line with all other channels.
    As you will know there are individual trims for all surround modes within the menu's.
    PL2
    TMS
    Direct + Sub
    DD
    DTS
    To suit individual program tastes.
    Also on the remote there is (the two buttons to the right of the curser controls) a tempory sub trim - marked LFE+/LFE- for on the fly changes.
    Pressing the Normal button (on remote) will restore defaults.
    Reckon you knew this anyway.
    Regards
    Steve.
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,788
    87
    Newcastle
    +116
    Thanks Steve
    Got it set to 75db. Yes I was aware that you can set different levels for TMS, DD etc
    Peter
