Quickie About Amp!
Discussion in 'AV Receivers & Amplifiers' started by betty02, Sep 17, 2007.
  1. betty02
    betty02
    Jun 2, 2007
    92
    11
    Ok if i bought this amp
    [​IMG]
    Its the 1707, now i has loads of video inputs, if i plugged all my inputs such as freeview, wii, dvd player into the amp and then the amp into the projector would this bassicly then work as a video splitter i would be able to switch between each pice of equiptment?
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,060
    The Shire
    +399
    Yes it would, an AV receiver is designed to act as a hub for your system so that all switching can be done through one box.
    Not all amps allow outputs to two displays though, so you may need a seperate splitter if you want to run video to both your projector and TV from the amp.
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    It works as a video switcher, however can it convert S-Video and composite inputs to component out?
  4. Jase
    Jase
    Mar 16, 2001
    10,939
    United Kingdom
    +3,304
    According to the German Manual, Yup. :)
  5. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The Oracle speaks!
    Cheers.:)
