Quick XP Help Question
Cowden_harley
Im about to fresh install my xp and was wondering if I could set it up so there was no accounts and it just started without selection of accounts etc.
Many Thanks
The Dude
I'm not 100% sure.. but I think if you just create the 1 user account required during setup, and use a blank password for that account, it should just log straight in automatically.
K
Kramer
Installing the .NET framework creates another account IIRC. XP may then start with the log-on screen.
This is easily enough fixed though........a search here should provide the necessary info.
:smoke:
rdhir
Install Windows XP Powertools - search Microsoft.com and specifically the TweakUI tool and you can auto log on a user.
Rajiv
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
