Quick XBOX Question-Answers Appreciated
Discussion in 'Xbox Forums' started by Cowden_harley, Jun 6, 2005.
  1. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    If i plug a component to 15pin vga cable into my ms hi-def pack and then into my vga port on my lcd will it display?
    Thanks for taking the time to read and reply.
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    No, I wouldn't think so - you'll need some sort of converter device to go inbetween. From what I gather, Component is a colour difference signal, whereas 15-pin VGA typically passes RGB video.
  3. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    473
    poole
    +10
    im not 100% on this but believe you need a seperate sync signal too , which you wont have . thats why the vga boxes for xbox normally retail for minimum £50 .Because there is a lot more involved then just connecting up the cables ,
    okies ? :thumbsup:
  4. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    thanks for your input guys.
