quick way of making my liteon dvd multi region please
Discussion in 'Desktop & Laptop Computers Forum' started by jmack, Jul 25, 2003.
  1. jmack
    jmack
    hi as title says
    the model is liteon ltr-52246s
    and free would be nice
  2. nathan_silly
    nathan_silly
    http://forum.rpc1.org/portal.php
    Search for your model, read instructions carefully.
    I would flash the drive in pure DOS mode (with a bootable MS-DOS floppy)
    Or use DVD Region Killer - I prefer to flash the drive, as I defently know it'll never lock out.
  3. jmack
    jmack
    cheers nathan
    i have downloaded dvd genie and its asked me to select a region and seems to work
    cheers
  4. nathan_silly
    nathan_silly
    DVD Genie does not solve the problem of the drive itself locking out. DVD Genie just changes the Windows Region.
    If you don't want the drive to lockup (with using DVD Genie or just normal 5 changes, you'll need to flash the drive- or use DVD Region Killer)
  5. jmack
    jmack
    is there any reason i cant just keap using dvd genie . as i dont use the pc for films much only in emergencys
    as i`m inbetween players moment
    :D
  6. nathan_silly
    nathan_silly
    Use this util...
    http://www.digital-digest.com/dvd/downloads/driveinfo.html
    To show the no of times left before your drive locks to the previous region. On some models, once it locks out- even if you flash the drive it doesn't reset the region code.
    So if you change it to region 9 on the last go... it's useless!! It won't play R1/R2 discs.
    I would stick to one region, and don't change it.. until you decide to flash the drive.
  7. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    I used this or something similar, have played hundreds of DVD's an no props on my Liteon.
    I used the winflash one I think. This is a software program that unlocks the drive in windows.
  8. TEK
    TEK
    I've just started using AnyDVD which is pretty good as well. It strips CSS stuff on the fly as well so if you're going to use something like DVD2One to make a backup copy of you film you don't need to run it through the likes of DvdDecrypter any more :)
    http://www.slysoft.com/
    21 day trial
