Quick Watt Question.
Discussion in 'Home Cinema Speakers' started by Stiesto, Jun 1, 2003.
  1. Stiesto
    Stiesto
    Oct 25, 2002
    61
    UK
    Well, its basically just be sure but here we go...
    Will it be OK to connect 75w(max) speakers (8Ohm, 6.4OHm min) to an amp (6Ohm-16Ohm per channel) with an 80w output per speaker channel?
    My assumption is yes as I will never be hitting full volume or even anywhere near it. Can anyone confirm this?
    Thanks.
  2. mjn
    mjn
    May 24, 2001
    22,067
    Herts, England
    +9,805
    is that 80w into 6 or 16 ohms?
  3. Stiesto
    Stiesto
    Oct 25, 2002
    61
    UK
    Well, its the impedance for each speaker channel (it has that rating next to each spring clip) so I'm guessing its a case of anything between 6 and 16Ohms is acceptable per speaker. The amp itself has an advertised nominal impredance of 6Ohms.
    Its really the watt thing that the question is hanging over.
  4. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    It should be okay ... but it might help people if you said what the speakers and the amp are.
  5. Stiesto
    Stiesto
    Oct 25, 2002
    61
    UK
    Yes, I suppose that would help.
    The Receiver/Amp is the Panasonic SAHE75.
    The speakers I am looking to buy are the MISSION CINEMA M70 PACKAGE (includes sub).
  6. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    They should be fine ... the Missions are easy to drive speakers ... so long as you arn't expecting reference levels of movie sound.
    Vikki
  7. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    Should be fine as long as you stick to that.
    MuFu.
  8. Stiesto
    Stiesto
    Oct 25, 2002
    61
    UK
    The most I've hit, and this wasn't a normal listening situation, just a test of volume, was something like -35db. It's a very small room so I'll always be hovering around -50db.
