Quick speaker placement Q
Discussion in 'Home Cinema Speakers' started by john-boro, Apr 17, 2005.
  1. john-boro
    john-boro
    My system is a marantz cd4000, tehcnics su-c04 and two airedale 801 speakers (set up for bedroom listening). Speaker placement is a bit of a problem, so at the moment i've got them roughly either side of my bed, around 3 feet away from my head. Since theyre small (12 inches tall) should this be okay? Or is it bad to have them facing towards each other as they are?
    thanks
    john
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    If it sounds good to you then its ok. I have found having speakers facing each other is a bad thing becasue it creates a 'tunnel' effect with the music. Can you set them up so they face you?
