Quick Simple Question
Discussion in 'Photography Forums' started by gtrplayer, Sep 4, 2004.
  1. gtrplayer
    gtrplayer
    Amateur photographer here just starting out. Got a nice little Fugi FinePix S5000.
    Would like a few things. Is there a "good" quality zoom lense that I can buy for it???? and if so how much zoom can I get???? it has 10x optical now, but need more.
    What sort of batteries do you recommend for longer life???
    I really want a good quality zoom lense....what can I use that will work with that camera?
    thanks!
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
  3. nobackwheel
    nobackwheel
    Sep 24, 2003
    85
    ascot
    you can get a tele-converter, which makes it 1.5X what you've got already - I just bought a wide angle convertor from softjam.co.uk for a s7000 (because they were the only place i could find that had it i stock) - try there. You can't get a zoom lens for it.
    I don't know what the optics are like though......
