Quick reply please no sound
Anastie
I have a Panasonic PD30 if I connect using the componant I get no sound. Yes I know Component carrys picture only. So I connect the two red and white to the audio at the back of the TV still no sound. Obviously using scart is ok but poor pq
What am I missing here.
CeeJay775
Anastie said:
Just make sure you are connecting to the right white and red, I myself made that mistake, turn the tv around to get a good look at where the component sound is.
Anastie
Thanks. Your answer prompted me to check something. The PD30 will give sound via comp if the scart is plugged in! Strange but it works and I get the comp quality pic :)
