Quick reply needed... ref HDMI to DVI
Discussion in 'Cables & Switches' started by MattDJ, Jan 6, 2005.
  1. MattDJ
    MattDJ
    Jan 1, 2005
    260
    Ive ordered a Panasonic S97... and likely to get a Philips 32pf9986 LCD...
    However, a kind fellow, Jimsan, explained about all the cables and more importantly a HDTV switcher (4 in DVI and 1 out DVI)...
    Heres the question. Panasonic to switcher unit, do i need a "standard HDMI to DVI" lead...? Does sound go thru it?
    and what does DVI-I and DVI-D mean...?
    and can i get a lead, VGA (PC) to DVI?
    Thanks In Advance!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,311
    Rainham Essex
    +2,425
    HDMI as standard carries stereo sound. A few devices are starting to be released with HDMI that can carry full multichannel audio. DVI is video only.
    DVI-I is an anlogue & digital signal via the DVI connection
    DVI-D is a digital connection via the DVI connection
    DVI-A is an anlogue only signal via the DVI connection
    I think the above is corect, but somebody else will either correct or confirm it.
    DVI-I & DVI-A carry a standard VGA analogue signal so yes you can get a DVI to VGA converter/lead.
    Mark.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    9 minutes - was that quick enough :thumbsup:
  4. MattDJ
    MattDJ
    Jan 1, 2005
    260
    Cheers guys... so what about audio then? If the output is HDMI on the Panasonic... and DVI input is Video only... im confused. Just trying to work out what I need to buy online at the mo.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,311
    Rainham Essex
    +2,425
    Sorry, I will practice my typeing and I'll get it down to 8 minutes by next week :devil:
    Sorry but I'm off down the pub for a :beer: in a minute so can't be bothered to check the audio inputs and outputs available on your equipment. The most likely solution will be a standard stereo pair of phono cables to take sound to the LCD.
    Mark.
  6. MattDJ
    MattDJ
    Jan 1, 2005
    260
    It wont be down to 8 mins after those pints LOL I think it is 2ch in aswell... same input as component unfortunately...
    Thanks! to all...
