Quick question
Discussion in 'Home Cinema Speakers' started by SHare, Jan 29, 2009.
  1. SHare
    SHare
    Dec 8, 2006
    37
    Ayrshire
    I have a set of Aego M's but should have a new receiver (yamaha DSP-AX761) arriving in the next day or two and would like to keep using the Aego's if possible til I get money for something more suitable. Does anyone here know the ohm rating of the Aego's and if it would be ok to use them with this amp?
  2. ChrisAV
    ChrisAV
    Dec 5, 2008
    766
    43
    Wirral
    +110
    Couldn't find the rating for Aego M's, but T's seem to be 8 Ohm, I'd surprised if M's were significantly different. Anyway, the 761 should be able to cope with anything down to to 4 Ohm. Just go easy on the volume.
    Chris
  3. SHare
    SHare
    Dec 8, 2006
    37
    Ayrshire
    Looks like I'm going to need some cable. Am I right in thinking I need to plug it all into the preouts? The cable with the Aego's is 2 rca and the other end has a black rca plug and bare red and white wires and I have no idea what thats meant to be for :rolleyes:
  4. Stoatman
    Stoatman
    Jan 26, 2005
    1,023
    +88
    I dont think i am 100 % sure what you are trying to do. Are you trying to use the aego M 2.1 speaker system by attaching it all - subwoofer included- to your new reciever/amp ?
  5. SHare
    SHare
    Dec 8, 2006
    37
    Ayrshire
    I had read on a couple of places that you could use the preouts to connect up the sub and speakers but the cable it provides for doing it doesn't appear to be what I need so I'm beginning to wonder. Failing that I'll just use the speakers on their own.
    <edit>
    No matter, I had a couple of coffee's then overcame my own idiocy. I just had to dig through my big box of random cables and find some straightforward RCA cables.
