Quick Question
Discussion in 'Headphones, Earphones & Portable Music' started by fatfingers73, Sep 9, 2007.
  1. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    I've just converted all my alac's into flac's using dbpoweramp. But it didn't keep the folders, now I have 5000+ flacs in one folder :confused:
    Is there any way round this?
    Thanks. :)
  2. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Do the files have complete tag info? If so, mp3tag (free) will rename files based on a template, including creating sub-dirs. A template like -
    %artist%\%album%\$num(%track%,2) - %title%
    Will completely rebuild the directory structure under where the files are now.
  3. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    Yep, Foobar can too. Media Monkey can also i think.
  4. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    Thanks for the replys, will these programmes actually create the folders again? Because I want to put all the flacs on my tvix 4100 so I really need the folders back.
    I still have all the alacs in thier individual folders, so I can convert them again if that would be easier.
    Thanks for your help. :)
  5. Empgamer
    Empgamer
    Jul 29, 2007
    533
    +10
    Are you using Reference? That has the capability to re-create folder structures when you convert. Not sure if the vanilla version supports this.
  6. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    Yes. When i use foobar it can recreate the folders and put the file in the right places. It does not modify the file (although they can be renamed etc during the move if you want).
  7. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    I couldn't work out how to do this using foobar, any chance of some quick instructions? :lease:
    Also will foobar do all 5000 in one go?
    Thanks.
  8. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    Yes.
