Quick question
Discussion in 'Digital TV & Video Players & Recorders' started by John Jennings, Feb 19, 2002.
Tags:
  1. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    If feeding an S-video signal into a S-VHS recorder, can you record that signal in a VHS form? Or will it give you a black & white signal if you try that?
    (Basically, will the recorder downgrade the S-video to Composite, or do you have to record S-video as S-video)
  2. DaveP
    DaveP
    I'm not sure I understand your question. Are you saying you will be using a normal VHS tape and not a S-VHS tape?
    If so then the quality of the recording will be to VHS standard. It will still be in colour.
    DaveP
  3. DaveP
    DaveP
    DaveP
  4. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    Yes, I mean recording on normal VHS tape.
    Specifically, what I want to know is can I make making a VHS recording (composite signal) from an S-video source (S-video signal).
    ie Will the recorder be able to convert the S-video signal (separate chroma and luminance signals) to a composite signal (combined chroma and luminance) when writing it to the tape.
  5. DaveP
    DaveP
    Yes, that works fine, I do it all the time, when I run out of S-VHS tapes!
    DaveP
  6. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    Just checking, but you do mean you do this from an S-video source (ie S-video Out from a digibox or DVD player), and not from a composite source (ie from analogue terrestrial, composite video-out from a digibox or from a VHS-only VCR)?
    If so I'll be happy :)
