I bought The Last of Us and after setting up the PS3 I noticed the controller doesn't work so need to buy a new one. If the DS4 works then I will buy one
One thing to beware of is that you can't power on the PS3 with the controller alone. You need to switch it on manually and then press the PS button to get it to work.
