Quick question
Discussion in 'Home Cinema Buying & Building' started by mattharesign, Mar 22, 2005.
  1. mattharesign
    mattharesign
    Mar 22, 2005
    372
    leeds
    I have just got my hands on a Panasonic SA HT870 system, but can't find any mention of it on the web.
    I have found the SC HT870.
    Is this the same system?
    Or is it different?
    :cool:
  2. Conn
    Conn
    Jan 2, 2005
    2,074
    +170
    Same I should think - the SA will refer to a component (player?) and the SC will refer to the sytem in total (speakers, etc). Does what you have got look like the pictures? :)
  3. mattharesign
    mattharesign
    Mar 22, 2005
    372
    leeds
  4. thewul
    thewul
    Oct 1, 2004
    275
    +15
    conn is right the SC is the system name and the SA refers to the amp section :)
