Quick Question
Discussion in 'Desktop & Laptop Computers Forum' started by chrisrich, Feb 19, 2005.
  1. chrisrich
    chrisrich
    Jun 10, 2004
    Does anyone run an "Abit ATI Radeon 9600XT 8xAGP 256MB DVI-I TV-Out" card on a sharp ga4 or another display where the EDID is set below the screens native resolution.
    I am trying to find out if this card will ignore the EDID allowing me to output a higher resolution.
    I'm possibly being slightly parinoid but I've just wasted £40 on a gforce 5200 fx and could do with not wasting another £80.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Did you try Powerstrip to force the resolution? Sometimes it works it seems even with broken EDIDs.
  3. chrisrich
    chrisrich
    Jun 10, 2004
    Tried everything :) brought a 9550 Radeon card from Maplins today all works fine. The Nvidia drivers just lock on to the EDID and if you specify a res over what it thinks the monitor is capable of then it just scrolls the screen. From reading a couple of Nvidia forums they have been on about fixing this for quite a while but havn't bothered (I think there are a few cards that work now something to do with an external timer I think, hard to remember what I was reading at 3:00 in the morning last night :) Anyway cheers for replying.
  4. DaveP
    DaveP
    I'm not familiar with your Sharp, presuably a pj?
    What is it's native resolution? I spent weeks trying to get 1:1 pixel mapping with my Sony HS20. It's res was 1366x768 but it reported it as 1024x768.
    If yours is the same you could do what I did and search for some help.
    Basically it does require powerstrip, at least to get it working. You may need a fresh install too, if youve had lots of different graphic cards.
    The ATIs are the best for this sort of thing. I gave up with the FX5200 that I had.
    I have it working now with my 9600SE.
    Dave
