QUICK QUESTION
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rob Skilbeck, Aug 6, 2001.
  1. Rob Skilbeck
    Rob Skilbeck
    Toshiba SD110 - worthwhile upgrade from a Wharfedale DVD750 in terms of picture and sound quality or are the two players so similar to be indistinguishable ?
  2. Rob Skilbeck
    Rob Skilbeck
    Thanks for all your help, y'all.
    Have bought the Tosh anyway and am well impressed with it.
    I'll try a second question - can anyone recommend a decent supplier of quality Scart leads, either online or otherwise ? The ones I use are at least five years old and there are some noticable<br /> 'watery' effects on shadows etc on DVD. My guess is new Scarts might improve the picture.
    Go on, prove you can answer a question....
    <img src="tongue.gif" border="0">
  3. TJSMANGINA
    TJSMANGINA
    try the qed range mate or the qed either cable is sweet.an i do believe you can get them from peters hifi if you have one local or try <a href="http://www.hifistore.co.uk./home.php?S=99a690676793755be7befabf4187a3c9" target="_blank">http://www.hifistore.co.uk./home.php?S=99a690676793755be7befabf4187a3c9</a> hope this helps <img src="smile.gif" border="0">
  4. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    You could also try lektropaks on-line, they do a professional range that I've been impressed by (not used the scarts though).
    Slingshot
