Mr Cat
this is I guess for either Bruce Hall or Hayes...
ok, I've got the CHT-10r which is a top sub - recently I've just used the 4 plastic cones that came with it - it sounds much better for films that it does music, tho when I play CDs it does seem to go down to a lower frequency, but it's not as tight....this kinda leads me to think that I could get better sound from it...
this is my setup -
details of my kit are in my signature, but the configuration is that when I play dvds I have the Nad and Yammy amps connected together with the Nad driving my main speakers, and the yammy driving the rest...this works very well as I only have to use the yammy remote to control the volume (and of course the velodyne remote to control the sub!)
when I want to play CDs - I disconnect the amps and plug the sub into my nad (see http://207.228.230.231/manual/NAD-C350.pdf for more info) in the the pre-out 1 (L) on the amp and the LFE phono on the sub...
is this the best way to connect the sub to my Nad..??
I've tried using a sub cable splitter (this one - http://www.tvcables.co.uk/cgi-bin/tvcables/XFA08-Y1F.html)
I've got a concrete floor with a carpet on it...
cheers
this is my setup -
cheers
