Quick Question
Discussion in 'Cables & Switches' started by CRAIGYBOY1, Aug 26, 2004.
  1. CRAIGYBOY1
    CRAIGYBOY1
    Feb 19, 2004
    12
    I'm at work at the Mo and unable to look at my plasma manual!!
    I want to connect up my fairly old PC to my panny pw6 when I get home. Is it a vga monitor lead I need?? If not what do I require??
    I wany to order it so its there when I get back.
    If anyone can recommend a supplier of a good 10ft cable also I would be grateful.
    Thanks for your help.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    CRAIGYBOY1
    01. Yes HD15 VGA Input on your Display.
    02. I'm not sure I can get one to you same day :) but certainly for Friday!
    Best regards
    Joe
  3. CRAIGYBOY1
    CRAIGYBOY1
    Feb 19, 2004
    12
    Thanks Joe. Amazingly quick reply.
    How much including postage for one around 10ft?
    Craig
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    Hello Craig
    You have a PM.
    Joe
