Quick Question: Removing Aego Speaker Grills?
Discussion in 'Home Cinema Speakers' started by burnt_sandwich, Dec 24, 2004.
  1. burnt_sandwich
    burnt_sandwich
    I have the Aego 2 Mk1 and they sound great, but I was wondering how you remove the speaker grills. Apparently they sound better with the grills off, so could anyone tell me how to take them off please?
    I have noticed that there is one big screw at the back of each satellite but I dont want to tamper with this incase the whole speaker falls apart...
  2. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    The grills just pull off from the front. They are a bit of a fight to get off though, I used a small screwdriver at the bottom end to get them started.
    Hope this helps :)
  3. burnt_sandwich
    burnt_sandwich
    Oh right thanks a lot. Works well.
