Quick question. re: TV's Audio Out
Discussion in 'General TV Discussions Forum' started by scartman, Mar 20, 2002.
  1. scartman
    scartman
    Mar 19, 2002
    10
    Hi all,
    Getting a 28" W/Screen TV to go with my DAV-S500. Does the TV need Audio Out connectors to be able to run the sound through the S500 speakers???
    Dave
  2. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    If you're just using terrestrial then I can't think of another way.
    Other options could include;
    1)Using the tuner on your VCR and using the audio out on that (a bit impractical though as you'd need to leave your VCR on the whole time and put the TV on the video channel.)
    2)If you've got satellite/cable then you could use the audio output from the set-top box.
  3. scartman
    scartman
    Mar 19, 2002
    10
    Nice one, narrowed down my TV choice to just a couple now!
    Cheers for the help
