Quick Question - Re Creating DivX Data DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Necro165, May 7, 2007.
  1. Necro165
    Necro165
    Jul 4, 2005
    34
    I'm trying to put some Divx files on to a data DVD disc using Nero but every time I try to burn, a prompt says I'm using the wrong disc type.
    I've got a DVD+R in the drive and I've used these before to create 'regular' DVD discs, so the question is:
    Can you only record data discs onto DVD-R?
    (I don't have any to be able to test this out.) If DVD+R should work, then I'm not sure why I'm unable to create a data disc and I'd appreciate any advice.
  2. geezagame
    geezagame
    DVD+R and DVD-R are both able to be used as data discs. Is it possible you have a faulty batch of discs? A compatibility issue between your discs and your recorder? A software bug?
    More questions than answers lol
  3. Necro165
    Necro165
    Jul 4, 2005
    34
    Well, the disc I used came from the same pack of 10 (Tesco's own ones) and the others have worked fine for other DVDs I've created from my PC (using Nero.) I have also tried a different disc but it still didn't work.
    However, I've also noticed that the error I get specifically says "Type of disc required: DVD-R/RW" so maybe it's a software problem with Nero?
    I'll go get some -Rs and see if that works.
    Thanks.
  4. nitram_tpr
    nitram_tpr
    Dec 26, 2006
    394
    Kent
    +75
    Can I recommend www.svp.co.uk I use them for all my discs, very reasonable prices :smashin:
    I hope this thread is O.K, I don't work for svp, just a recommendation :cool:
    Verbatims are generally recognised as being a top notch disc.
  5. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    AVOID Tescos data DVD's.
    I have had the same problem with those discs on certain PC burners.
    Compatiblity issue most likely.
