Quick Question re: Battery Charging
Discussion in 'Photography Forums' started by alastair, Jun 8, 2004.
  1. alastair
    alastair
    May 11, 2004
    53
    Northumberland/York
    How long should i charge my Pentax Optio S4 battery for the first time, the normal 12 hours or just until full?
    Tahnks
    Alastair
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,405
    Rainham Essex
    +2,452
    The first charge of any battery should be for at least 12 hours. If you stop after the charger says the battery is full you will not get the best out of your battery and could even shorten the life of the batery permanently.
    Stick it on charge overnight and forget it till the morning.
    Mark.
  3. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    The Pentax Optio S manual does not recommend a time. Also, I underdsand that the charger does not trickle charge, and Pentax recommend removing the battery from the charger once it is charged (after 100 minutes from flat)
    The last 5 electronic devices that I have bought, do not mention anything about a 12-14 hour intitial charge. So I can not see any benefit from charging for 14 hours if the manufacturer does not ask you to, nor if the charger switches off after the battery is charged.
    However, shop assistants (particularly from mobile phone shops) seem to always tell you to charge for 14 hours initially.
