Quick question: PLIIx on AV32R 192 SP 7.1?
Discussion in 'TAG McLaren Audio Owners' Forum' started by Bolle, Apr 27, 2005.
  1. Bolle
    Bolle
    Jan 10, 2005
    274
    The Hague
    +20
    maybe a stupid question, but I can't seem to find a clear answer.
    Is Prologic IIx present or possible on an AV32R BP192 7.1 single processor model?
    I know the DP's have it, but I don't know about the SP's.
    Cheers,
    Menno
  2. PietDV
    PietDV
    Apr 8, 2005
    11
    3
    No the processing power is much less on a SP then on a DP and PLIIx needs a lot of processing power.
  3. Bolle
    Bolle
    Jan 10, 2005
    274
    The Hague
    +20
    Ok thanks,
    will sleep another night on it then if I'm going to upgrade from my AV32R 96 5.1 to an AV32R BP192 7.1...
