quick question: please help
Discussion in 'Projectors, Screens & Video Processors' started by Shadow Jam, Nov 5, 2005.
  1. Shadow Jam
    Shadow Jam
    ok just got my z2... nice and lovely, spent half an hour setting it up and finally managed to get it running my ps2 signal (in colour)
    then im confronted with a problem. where is the volume?
    i know it doesnt have an internal speaker but it never occured to me it wouldnt have a fitting for speakers itself... my ps2 doesnt, nor does my dvd player...
    am i just being stupid or am i gonna have to go buy a new dvd player or seomthing?
  2. Anim
    Anim
    Feb 2, 2002
    1,686
    Bollington, Macclesfield
    +62
    Most home cinema projectors dont have internal speakers as they are just don't do any justice to the big picture.
    Your PS2 has a Digital TOS link output to go into an amplifer doesnt it?
    EDIT: You should get a 5.1 Amp or something to drive the sound for DVD/Playstation/Cable and Sky etc or use a PC and its speakers (line in) for the sound.
  3. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    there is no audio circuitry in most projectors , audio has to come through an amplifier of some description. Mike
  4. Shadow Jam
    Shadow Jam
    without sounding stupid what the heck is an amp... i was just planning on using my pc speakers, which have headphone connectors
  5. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    er, an amp is what amplifiers the signal so normal hifi speakers can play the sounds..
    if you want to use PC speakers that use a 3.5mm input then you need to get a stereo RCA to 3.5mm cable (dixons do them in their JVC range) and plug from the stereo output of the PS2 (i assume the PS2 has a normal stereo output, as in red and white sockets)
  6. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    or if the PS2 has a 3.5mm headphone output socket, then just get a 3.5mm to 3.5mm cable.....not sure if the JVC range in dixons does that, you should be able to get one from www.maplin.co.uk tho....
  7. Shadow Jam
    Shadow Jam
    i dont believe the ps2 has any output sockets for sound... not mine at least which is the fat version...
    the only sockets i see are a little square one at the front and two rectangular ones undeneath
  8. Shadow Jam
    Shadow Jam
    ok so i just went and got a dvd with audio output, the only thing is i get home to find out that the audio output seems to be for a rgb sized cable, though i thought rgb cables weren't for audio...
    i swear to god this is never gonna get fixed...
  9. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    when you say RGB output, i take it you mean a Scart socket?.....
    on the back of the DVD player there should be a pair of little plugs, one red, one white, labelled L and R or Left and Right Audio........those use a stereo RCA cable to connect to a hifi.....but if u want to connect to computer speakers that use a 3.5mm input, then you need to buy a 'stereo RCA to 3.5mm jack' cable........OR if the DVD player has a headphone socket, get a 3.5mm jack to 3.5mm jack cable and use that (the DVD players headphone socket may be 1/4in size, if so you need to buy a 1/4in to 3.5mm adaptor as well)
  10. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    if it doesnt have those red and white sockets on the back or a headphone socket on the front or back, then if it uses Scart, try buying a Scart cable that ONLY carries sound......it will be Scart plug one end, the other end will just be stereo RCA (usually Red and White plug, like a thick pin you could say)..........then get a 'twin female RCA to 3.5mm adaptor cable' to convert it to the right kind of input for the computer speakers....
  11. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    btw, if my advice hasnt helped, i would suggest the easiest thing you do is take the DVD player and your computer speakers in to a hifi shop and ask them how you can get sound from DVD player to speakers while watching a film on your projector.....it may be a bit cumbersome, but at least they will then be able to tell you exactly what you need as they can see the equipment...
