Quick question - Panny PW7 power lead description
Discussion in 'Plasma TVs Forum' started by Tommo21, Nov 9, 2004.
  1. Tommo21
    Tommo21
    One thing I forgot to check whilst in the local Panasonic shop, was what type of power lead the PW7 use, can anyone tell me - is it like a monitor, kettle plug type plus length ? or is it built in, again the length (wall mounting mine, need to measure !)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    IEC COLD PLUG (similar to kettle) length is 2.5m??? not sure you can buy the bits to make your aown from CPC/Farnell if you need a longer one
