Quick question - PAL Xbox, enigmah switched to NTSC, no Prog Scan options! :(
Tom Whitaker
As in the header, I've switched it over to NTSC and it HAS worked (the PAL-60 option has disappeared from the MS Dashboard video settings), but no prog scan ones have appeared.
Currently awaiting my Xbox High Def cable... will they appear once that's plugged in?
Anjou
Yes, I believe the Xbox detects what lead is plugged in and gives you the appropriate options. Let me know how you get on.
PC Nut
Can you let me know where you got the high def cable and what chip you used and any usefull web links would be great.
Many thanks PC Nut.
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
