Quick question on speaker cable length
-=Rob=-
I'm just wiring up a floating wall project and have a query on speaker cable length... My right and centre speakers are at 4m of cable, but my left is 3.25m as I ran out of cable! I'm not sure if I should get another reel or if this will be ok? I do have some odds and ends I could use and solder-join to make up the length, but again I'm not sure this is wise either? Will the shortage of 75cm On the left cause any issues accross the fronts? Cheers
Joe Fernand
AVForums Sponsor
Unless you talking about maybe a 100m difference between one or two channels then no 0.75m is not going to make a difference.
Joe
-=Rob=-
Thats great thanks Joe...
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
