quick question on Humax PVR8000T
Discussion in 'Digital TV & Video Players & Recorders' started by swanytroon, Aug 17, 2004.
Tags:
  1. swanytroon
    swanytroon
    Apr 4, 2004
    957
    +10
    im think about buying the Humax PVR8000T but dont get freeview in my area will it still work wif noraml tv e.g channel 1 2 3 and 4
  2. pr1uk
    pr1uk
  3. swanytroon
    swanytroon
    Apr 4, 2004
    957
    +10
  4. Tetlee
    Tetlee
    Jan 21, 2004
    20,310
    Taunton
    +4,806
    It might be worth (if you are able) trying someone elses freeview box rather than relying on those postcode checkers. When I checked my postcode (also dixons checked with their books) it said I was unable to receive here. Then someone told me it should be ok so I tried a box and it worked just fine (I did need to fit an external arial).
    One thing I would say though, I tried the Pace Twin and I was getting loads of picture freeze, however the Humax PVR8000 has been as good as gold, I'd really recommend it if you can use it. Seems to be good at making the most of a weak signal. Also it's a bargain now and damn near perfect piece of kit :thumbsup:
  5. Flak_Munky
    Flak_Munky
    Swany,
    If you can't get Freeview in your area, then the PVR-8000T will not be much use to you. :eek:
    The way I read your post, you are wondering if you will be able to record analogue BBC1, BBC2, ITV, CH4, CH5 . If this is the case, the answer to your question is that the 8kT can only record from the internal digital tuner; it cannot record from any analogue source.
    Have a look at an FAQ I wrote at: :spam:
    http://www.radioandtelly.co.uk/cgi-bin/forum/YaBB.pl?board=freeviewbox;action=display;num=1092477481
    That will answer many of your questions.
    If you can get Freeview in your area, the 8kT is a superb machine, :thumbsup: especially now the 7/8 day EPG has been rolled out. :clap:
    Kind Regards,
    fM
  6. swanytroon
    swanytroon
    Apr 4, 2004
    957
    +10
    ok thanks 4 all your help
  7. pr1uk
    pr1uk
