Quick Question (NEED ANSWER ASAP!)
BandofBrothers
K
kmhtkmhtkmht
WOW that price is retarded...
1600?!?!?!?!!?
It's 1311 Delivered from Pixmania!
vipergrm
It only has one Component connection according to the offical specification on the Samsung website HERE
:smashin:
vipergrm
Has 5 years warranty though and probably includes the stand.
BandofBrothers
:smashin:
looks like I will be doing the following then:
DVD PLAYER-->TV with HDMI CABLE
XBOX360-->TV WITH COMPONENT CABLE
cooleo_no1
Don't forget BandofBrothers.
If you buy the Premium Xbox 360 it comes with a component cable. Also, only official/3rd party cables designed for 360 will work. Remember the 360 has a special individual output on the back, so don't buy any normal cables.
I bet you already knew that, but just wanted to save you some money if you didn't. In the other thread someone recommended you should get a component cable, but unless you really need one for your DVD player then you probably won't need one, as a HDMI would do a better job.
BandofBrothers
yeah thanks "cooleo_no1" :thumbsup:
I realised the other night, I looked at a pic of the xbox360 and realised it was a "special" cable.
So Im gonna give the component cables a miss for now, and will just use the one that comes with it.
Thx again for all the info guys Im sorted now I know what I am doing :cool: :smashin:
Trending threads
Trending threads
