Quick question for those of you with Sky+ and a HDD Dvd Recorder
Discussion in 'Sky Digital TV Forum' started by davidcotton, Dec 12, 2004.
  1. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
    Since getting a working sky plus box I've been impressed with it. Now I want to replace the knackered vhs recorder with a dvd recorder.
    I've narrowed it down to three models. But now I'm stumped. The models are :-
    Toshiba xs32
    Panasonic E55
    Panasonic E85
    Now I'm not going to be using it that much, but would like one just in case either a) a friend wants something taping from sky, or b) I want to keep something that I've recorded my self.
    So the question is, how useful have you found having the dvd recorder with a hard drive in? Have you used it as much as you thought you would? Or less? Also how easy is the tosh (Yes I've read THAT thread :) )to use?
    Cheers.
  2. applevenus
    applevenus
    have definitely found it useful (I have a Panny HS2). Although now that I've put a 250GB HD into my Sky+ box I don't need to transfer to DVD-R as much as I did before.
    It's great getting all those Jools Holland shows and some of the one-off music concerts onto DVD-R.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Same here. I couldn't afford a DVD recorder with HDD, but I bought it primarily to cope with a rapidly-filling Sky+ hard disk. Since upgrading my Sky+ to a 200GB drive, I've not filled it beyond 60%.
  4. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
    So it looks like the best bet would be an upgraded Sky + and a panny e55 just to burn the discs then? I don't really care about ads, and can fast forward them anyway.
  5. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    How do you upgrade a Sky+ Box hard-disk. Mine is the basic 40gb, and yes you've guessed, it doesn't take too long to fill it.
    Mike
  6. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
  7. WarPig843
    WarPig843
    Oct 21, 2004
    304
    +19
    Most local independant satalite shops will upgade it for you.
