quick question for the LG RZ-42PX11 owners
Discussion in 'LG TVs Forum' started by tabs, Apr 25, 2005.
  1. tabs
    tabs
    Apr 3, 2005
    1,974
    warks
    +129
    do the connections on the above come from the rear or underneath, just checking if i need the extra depth bars on the rs100 bracket, thanks
  2. RexConnix
    RexConnix
    The scart connection are on the back but do stick out all other connection are underneath or on the side. Hope this helps
  3. Daddy k
    Daddy k
    Jul 19, 2004
    9,081
    coventry
    +1,345
    more precise, scarts are at the back facing out dvi, vga svideo and componant composite are at back facing down, there is planty of space for all connections if flat against wall! there is also s video and composite at the side just out of view, buit easy quick access
  4. zorg
    zorg
