Quick question for Pioneer 2011 owners
Discussion in 'AV Receivers & Amplifiers' started by juboy, Feb 20, 2003.
Tags:
  1. juboy
    juboy
    I'm aware that the 2011 has assignable channels of amplification but wondered how flexible that is.
    To cut to the chase, what I'm hoping to do is have a 6.1 speaker set-up but with the 'spare' 7th channel of amplification used to bi-amp the front centre speaker.
    Would this be possible?
    Thanks for any suggestions.
  2. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    I have the VSA-AX10, and there you can only use the B-channel speakers to bi-amp the front L/R speakers. Dunno how the 2011 does things though.
  3. juboy
    juboy
    Thanks for that, but I would imagine that if you do bi-amp the front L/R then you can only run the amp in 5.1?
  4. avdesigns
    avdesigns
    You cannot bi-amp the centre just using the 2011. If you bi-amp the L & R then you can only run as 5.1
  5. juboy
    juboy
    Thanks avdesigns, I guessed that would be the case... no harm in hoping though eh? :)
