Quick question - buying DS in the states?
holden
I'm currently staying in the states for a few weeks, and im seriously considering buying the DSlite (@ $129.00 I'd be a fool not to). However i'm worried that I will not be able to charge the battery back home.
Has anyone purchased one in the sates, or does any one know if it is OK to charge a US DS in the UK? Do I need to buy a seperate battery charger, or can I chrage it with a USB via the computer.
I appreciate any advice you guys can offer.
Thanks in advance.
Kazman
holden said:
Thanks in advance.
If all else fails, Maplins can be your best friend as they sell good value step down transformers you can use. :)
I'm not sure if the charger is an auto switching dual voltage jobbie.
Soundwave
I'm sure there is a USB charger available which might be your best bet other than that you can get the chargers from Game for not alot of money now.
Neil
samwiseadams
If you buy a UK ds lite charger when you return it will work fine on the us ds lite - my wife used to have a us ds original and used a uk charger on that and now has a japanese ds lite and uses my uk ds lite charger on that, no problems at all. Hope that makes sense!
bbdivo
Lyris said:
Yeah, just buy a UK charger - it works perfectly.
They are not that expensive either, Lik-sang will ship them from their european warehouse, I think they are under a fiver.
holden
Thanks guys, very helpfull advice - Im on my way to Best Buy now!:)
Can you recomnded a couple of good games to start with??
