Quick question - AE100 bulbs, where?
Discussion in 'Projectors, Screens & Video Processors' started by Dystran, Jan 28, 2004.
  1. Dystran
    Dystran
    Jan 25, 2004
    165
    16
    Hello I have an AE100 - I wondered, its probably about time I buy a replacement bulb before they stop producing them perhaps? (even though I have a fair amount fo time left).
    Any ideas where I can get a bulk one from?
    Also, in your opinon how long are these bulbs likely to be available for?
    Many thanks for any advice
  2. beecee
    beecee
    Dec 8, 2003
    2,263
    2
    87
    Kirkcaldy, Fife
    +434
  3. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    Unless you are going to need one in the next year I`d think about whether it`s worth getting one. In a year`s time its likely the AE300 will be down to about 600 quid in price, with the AE500 not much more. Is it worth spending nearly 300 quid on a lamp for an aging projector when a new and better projector only costs twice that? In my opinion (and I own a AE100) , I think I will just buy a new projector when my bulb runs out. (which at the rate I`m going maybe about 2010!)
    Chris
  4. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    i put 3200hrs on my pta100 in 18 months and after that time the picture started to look alot duller coupled with the fact i was starting to see some heat damage to the optics,
    thus i decided to upgrade to the 300 rather than pay £300 for a new bulb. It cost me just over a grand (i paid £1400 for my 100 :eek: )
    so in net terms i only had to pay £700 extra for a better machine.
    my intention is to use it alot less than the 100 so i can keep the 300 for a bit longer
