Quick Question about the Canton Cd-1
Discussion in 'Home Cinema Speakers' started by bigbfan, Aug 22, 2005.
  1. bigbfan
    bigbfan
    Jul 13, 2003
    2,221
    +112
    Hello..
    I just ordered the Canton CD-1 package from Jake (thanks jake).. however can you please tell me what cable I would need to connect the sub to my amp... Do I need "Y" cable or a single mono cable... does that make sense.. :oops:
  2. Troon
    Troon
    Apr 28, 2005
    151
    The sub comes with a short Y-cable adaptor (1 phono socket to 2 phono plugs), but you don't need to use it. A mono cable is fine: connect to either input.
    Using the Y cable will get you extra gain, as the sub sums the L-R inputs, but you should be able to turn it up enough without.
